Discussion topic: Mobile data doesn’t work
Message posted on 08 Oct 2026 11:17 AM
My phone does not work when I use mobile data, phone and text messages.
I also have an eSIM as well as my sky sim and doesn't work properly
many thanks,
Message posted on 08 Oct 2026 12:01 PM
Re: Mobile data doesn’t work
Has it been working up to now ?
Have you move your mobile number to Sky and it hasn't worked since ?
Message posted on 08 Oct 2026 12:10 PM
Hi I just recently changed to sky 3 months ago from O2 and it was working fine until I changed to Sky.
Message posted on 08 Oct 2026 12:13 PM
I also have two moline numbers one for sky and my old number from O2
Message posted on 08 Oct 2026 12:15 PM
What phone have you got ?
Message posted on 08 Oct 2026 12:34 PM
iPhone 17 pro max
Message posted on 08 Oct 2026 01:02 PM
As this is an iphone try refreshing the network settings so go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
Message posted on 08 Oct 2026 02:16 PM
I have just tried that and it still doesn't work
