Discussion topic: Making calls from Philippines
Message posted on 19 Mar 2025 09:09 AM
I am in the Philippines and can't make or receive calls
Message posted on 19 Mar 2025 09:19 AM
Re: Making calls from Philippines
It's a 'rest of world' location so is very expensive.
£2,160 per Gig of data (yes 2 thousand pounds)
£2.16 per minute to make calls
£1.80 per minute to receive calls
You may have already hit your spend cap.
Message posted on 19 Mar 2025 09:47 AM
Thank you ...... and sorry I'm a bit of an old dinosaur but how did you overcome this issue ??
Message posted on 19 Mar 2025 10:02 AM
If you have a spend cap set then you can increase it here:
https://www.sky.com/myaccount/mobile/sim/x/settings/spend-cap
It's not clear what your issue is.
If you have hit your spend cap then you cannot continue until you increase/remove it.
Message posted on 19 Mar 2025 02:03 PM
Be aware that removing the spending cap would be extremely unwise as you'd then be liable for a potentially unlimited bill. In particular do not do so while having cellular data switched on.
Message posted on 19 Mar 2025 10:11 PM
Thank you all for your help ....... I am stuck in a hospital in Manila and don't need data but I do need to make some urgent calls to the UK.
I appreciate the callls are not cheap but the few I need to make are quite urgent.
At the moment I can't make or receive any calls which means I can't even sort this issue out with SKY.
