Discussion topic: Iphone help required urgently
This message was authored by: BVERONICA
Message posted on 04 Jun 2026 11:48 AM
I am unable to send message, make calls on my new Iphone. Its an Iphone 16. what do i need to do get sorted
Find out more
Message posted on 04 Jun 2026 11:50 AM
Re: Iphone help required urgently
Have you put a SIM in it?
This message was authored by: twilight+princess
Find out more
Message posted on 04 Jun 2026 03:18 PM
Is there a SIM card or eSIM installed?
Does the phone show the correct number?
Are you transferring your number from your old provider? If so then when did you give SKy the PAC code?
Have you signed into your Sky mobile account & sent the settings to your phone?
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
