Discussion topic: Internet connection problem
This message was authored by: Sandis
I have sim card and phone from the sky bit my sim card all the time show " you maybe out of the data, tap for options ' I have unlimited data, calls and messages.
Re: Internet connection problem
If you are on an unlimited plan then you can ignore this message, so are you sure that it isn't your phone that is creating this message and not the MySky app if you have this installed on it ?
