Discussion topic: Incorrect bill
Message posted on 27 Jul 2025 02:16 PM
Incorrect bill
Hi, I’ve received messages saying I’ve hit my £45 data roaming spend cap, but I believe this is an error. I’ve been using a Thailand eSIM for data and had data roaming turned off on my Sky SIM the whole time.
Could you please check if there’s been any data usage on my Sky SIM and look into refunding the charge if it was applied incorrectly?
Message posted on 27 Jul 2025 02:21 PM
Re: Incorrect bill
@Izzieholt
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
It will depend on when you switched off data roaming. You should have switched it off prior to leaving the UK so there's every chance you've actually been charged correctly.
