Discussion topic: How to cancel and incorrect order
This message was authored by: Monika79
Ordered the wrong phone in error.  It's on a delay.  How do we cancel and reorder?
Re: How to cancel and incorrect order
@Monika79  You will need to call Sky.  These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
@Monika79
And if you order an alternative device you will undergo further credit checks.
This message was authored by: Mohdusman786
Hey, I'm Mohd usman I accidentally ordered I phone 17pro max and apple airpodes 4th generation noise cancelling and you cancel my order of phone but deducted 12pounds of phone and 210 pounds for airpodes I don't want airpodes as well can you please help me with full refund
thanks
Mohd usman
@Mohdusman786
Any upfront payment you’ve made should be refunded after about 14 days but recent posts suggest it’s taking a bit longer in which case you’ll need to contact Sky to chase it up.
