Discussion topic: Help with the Sky standard SIM pin code please
This message was authored by: Jillian16
Hey
Recently joined Sky Mobile and am unable to locate on the card sending through the SIM card any standard PIN code for the SIM card. I am looking to convert to an eSIM but am unable to do this without the SIM PIN code. I have tried twice now and only have one try left before I cause myself a major headache by locking the SIM card altogether.
Any ideas please?
Re: Help with the Sky standard SIM pin code please
@Jillian16
Is this a handset from Sky (which won't be network locked) or a Sky SIM going into a handset obtained elsewhere?
Avatar for Jillian16
Thanks for your response, it is an iPhone contracted with Sky with a Sky SIM.
Hi @Jillian16  its usually 0000 for iPhones.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Thank you, I took the chance and it worked - 0000 it was.
Appreciate the help guys!
