Discussion topic: Going to Spain
This message was authored by: Steph684
Going to Spain
I've just upped my spend cap as I'm going to Spain tomorrow for 5 days, how do I pay the £2 a day roaming passport or will it just put it on when I get there?
Re: Going to Spain
@Steph684
For that country it should cost you £2 for each 24 hours use of your home allowance.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in automatically when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there.
Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage duel to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
Re: Going to Spain
The charge for this @Steph684 is added to your next available bill. So if your next mobile bill is due to be paid in the next 14 days or less you should see this on the following one.
