3
This discussion topic has been answered Discussion topic: Going on holiday
This message was authored by: charitylady
Going on holiday
Hi, Im going abroad ( rome) in may. Both our phones are with Sky. Can i buy a plan for using abroad . Im green never used my phone abroad before. Thank you
Re: Going on holiday
@charitylady
For Italy it should cost you £2 for each 24 hours use of your home allowance.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage duel to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
@charitylady
@charitylady
There is no package you but when going abroad as you are charged when you start to use your phone.
This message was authored by: Goodison9
You should be aware calling a local toll free number from your uk mobile will charged as an international call at £3.50 per minute
