Discussion topic: Going abroad
Message posted on 05 Sep 2024 08:04 AM
Going abroad
How do I add on being able to have data abroad
Message posted on 05 Sep 2024 08:09 AM
Re: Going abroad
You just need to make sure roaming is turned on in your phone settings and you have set a spend cap sufficient for the £2 a day charge. As soon as you send a text, make a call or use some data it kicks in. You haven't said where you are going so be aware it's only in certain countries that it works like that. If you're in a 'rest of the world' country then the charges are much higher.
Message posted on 05 Sep 2024 08:14 AM
Re: Going abroad
Thank you, I'm going to Norway
Message posted on 05 Sep 2024 09:11 AM
Re: Going abroad
@Mills891 wrote:Thank you, I'm going to Norway
Norway is covered by the passport: https://www.sky.com/help/articles/sky-mobile-roaming-passport-plus
Message posted on 05 Sep 2024 10:32 AM - last edited: 05 Sep 2024 10:34 AM
Re: Going abroad
Included through being in the EEA rather than the EU, I believe. Or possibly the EFTA.
