5
This discussion topic has been answered Discussion topic: Extend ring duration
This message was authored by: Colin24415606
U have an iPhone 16 and when receiving calls, it only rings 3 times then goes to voicemail. How do I extend the ringtone before time. I've tried 61*mynumber*11*30# and it comes up with an error. Help please?
Avatar for Colin24415606
This message was authored by: Colin24415606 Answer
Re: Extend ring duration
The solution (for me) was this:
**61*voicemailnumber**30#
THEN restart phone for change to take effect. My phone now rings for 39 seconds before going to VM.
I have an iPhone 16 and when receiving calls, it only rings 3 times then goes to voicemail. How do I extend the ringtone time? I've tried 61*mynumber*11*30# and it comes up with an error. Help please?
@Colin24415606
It looks like it isn't your number that you enter as shown here under voicemail settings:
https://www.sky.com/help/articles/sky-mobile-voicemail
Thanks caesarome,
Looks like you're right, the link shows the correct mobile number to use.
Thanks for your help.:
Colin
I used the correct message format to extend ring time to ,30 secs and it took it without error. Tested it but still goes to voicemail after 3 rings!
Answered - Go to Answer
