08 Feb 2024 07:10 PM
I have an issue with Sky Voicemail. When I call it says 'your voicemail is disabled, call Sky to turn it back on'.
I have called Sky who escalated the problem to the tech team. I was sent a text to do the following.
Dial *52 to enable voicemail. Dial *53 to disable voicemail.
When I followed the above instructions it stated the following. 'You are not allowed to call this number'.
I've replaced the sim and reset the phone but it seems a Sky issue.
Any advice would save me from taking a long walk off a short pier.
Many thanks in advance.
08 Feb 2024 07:11 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Anonymous have a look here.
https://www.sky.com/help/articles/sky-mobile-voicemail
08 Feb 2024 07:14 PM
I'm not sure you read my post. I did call and it states it is switched off and I should call Sky to switch back on.
08 Feb 2024 07:26 PM
Posted by a Superuser, not a Sky employee. Find out moreI did read your post @Anonymous but the instructions you were given do not match up with the help pages hence I posted a link to the help pages which include turning voicemail on. Good luck getting sorted.
08 Feb 2024 07:49 PM
@63johnw best of luck achieving level 17. Your post is not helpful, in fact, you post the same reply to similar posts. It does not work in my situation so why post. Your surely aware the reply is not appropriate nor helpful. Best of luck to you as well chum.
19 Feb 2024 09:24 PM
I have had issues as well with trying to reset my voicemail pins so I can actually access my voicemail messages.
I appreciate your comment. @Anonymous and I too hope this gets resolved expedititiously.
