Discussion topic: Doogee S200. No internet connection when using mobile data
This message was authored by: Swoop
I'm not able to connect to the internet or use apps when away from my WiFi using mobile data.
Re: Doogee S200. No internet connection when using mobile data
Hi @Swoop  you will need to check you have the correct APN settings in your mobile settings in your phone.
It should be
Internet APN Settings:
Name: Sky Mobile Internet
APN: mobile.sky
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Swoop
Thanks John. I'm set up as you say but still doesn't work
