Discussion topic: Do I need a sim for iPhone 17 pro
Message posted on 03 Nov 2025 08:21 PM
I have changed from an iPhone 14 to iPhone 17 pro and cannot find a definitive answer regarding the sim. Do I need a new sim (iPhone 14 sim one won't fit in iPhone 17 pro) or is it automatically an eSIM?
Message posted on 03 Nov 2025 08:26 PM
Re: Do I need a sim for iPhone 17 pro
Hi @MishMash69 if buying the iPhone 17 pro from sky then yes the sim from a 14 will fit. If you wanted to you can also convert the physical sim to an esim.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 03 Nov 2025 08:29 PM
Thank you - there is no "notch" in the sim tray so it doesn't seem to fit.
Is it relatively easy to change to an esim?
Message posted on 03 Nov 2025 08:31 PM
The nano sim in your 14 should definitely fit @MishMash69 but it should be fairly easy to switch if you wanted to.
https://www.sky.com/help/articles/esim-sky-mobile-activate-and-install
Message posted on 03 Nov 2025 08:33 PM
Thanks again - I will give it another go
Message posted on 03 Nov 2025 08:34 PM
Google sim tray iPhone 17 pro @MishMash69 and videos will come up.
