Discussion topic: Deactivate Sky Mobile Voicemail
Message posted on 05 Nov 2024 04:25 PM
I want to deactivate my Sky Mobile Ireland Voicemail. I went through the online guide and called 179 as instructed (and 759 but this may be for UK only) but just get a disconnect tone. I understand that it cant be fully removed but I just want not to have the feature turned on.
Anyone able to help?
Message posted on 05 Nov 2024 05:55 PM
Re: Deactivate Sky Mobile Voicemail
Have you tried calling Skynto see if they can change the voicemail setting for you. I believe you can call them on 150
Message posted on 07 Nov 2024 02:45 PM
Thanks but I when I call that number (150) I just get a invalid number tone. Not sure if that number works on the Uk but I'm in Ireland and it doesn't seem to work 🤔
