Discussion topic: Data running out every month
Message posted on 28 Jul 2026 08:30 AM
Can you help
My data keeps running out and I have to top up with piggy bank. Nothing has changed and I e had this plan for years , but since I've had sky tv fitted my data doesn't last. Before this I always had data carried over from previous month
Message posted on 28 Jul 2026 09:12 AM
Re: Data running out every month
Unless you,are using your data to stream to your TV then it's irrelevant.
You'll have to use your phone's data counters to see where the data is going...
Message posted on 28 Jul 2026 09:29 AM
When you are at home so your phone is connected to your wifi network then turn mobile data off so that should the wifi connection drop mobile data will not take over.
