Discussion topic: Data roaming
This message was authored by: 2010ktnv
Data roaming
Going on holiday to Morocco Marrakesh and the WiFi isn't great how do I make sure my phone will work as it does in uk
Re: Data roaming
@2010ktnv
Well there are no guarantees on the quality of coverage whilst abroad.
For that country it should cost you £2 for each 24 hours use of your home allowance.
You need to ensure roaming and mobile data are turned on in your phone settings and it will kick in when you send a text, make a call or use a small amount of data. Set any spend cap to cover the total number of days you are there. Remember that calls to local numbers are charged extra at international rates and there is now a limit on data use of 25GB per billing period, after which Sky can charge you an extra £2.50 per GB or even suspend your useage duel to overuse.
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
