Discussion topic: Data roaming
Message posted on 05 Mar 2025 03:31 PM
Data roaming
I am travelling to Zimbabwe tonight and will switch off data roaming. When I am there, if I am in Wi-Fi and I switch my data roaming on, will I still be charged?
Message posted on 05 Mar 2025 03:37 PM - last edited: 05 Mar 2025 03:37 PM
Re: Data roaming
Why would you turn on data roaming to use WiFi? (Data roaming is cellular only)
I would recommend putting the device in flight mode - you can still connect to WiFi.
Message posted on 05 Mar 2025 09:06 PM - last edited: 05 Mar 2025 09:26 PM
Re: Data roaming
That's extremely unwise in any country with 'rest of world' pricing: should your phone decide to use cellular data instead of (or in addition to) WiFi the bill run up in a few minutes would be very unpleasant if the default £45 cap isn't in place.
Cellular data using a Sky SIM in Zimbabwe is £4.32 per megabyte (twice as much as most RoW locations) or about ten grand for an hour of Netflix.
