2
This discussion topic has been answered Discussion topic: Data roaming
This message was authored by: Nowei54
Data roaming
How do I enable data roaming..I'm a platinum vip user
Re: Data roaming
@Nowei54
You turn roaming on via the mobile data section of your settings app.
If you are travelling to any of the 120 countries where the £2 daily charge is applied (or is free if you are a diamond VIp customer) then data is limited to 25GB per billing period or you are charged for each GB you use.
Re: Data roaming
@Nowei54
Avatar for Nowei54
Re: Data roaming
Fantastic thank you
Answered - Go to Answer
