Discussion topic: Data roaming not working in corfu
This message was authored by: Neil1175
I have plenty of rolled over data and more in my piggy bank but for some reason it's not working. I had. £45 data limit but have turned that off. Any ideas?
Re: Data roaming not working in corfu
@Neil1175
Long shot but perhaps try setting a spending limit to see if that helps or get your device to search for other networks to see if it will connect and work with a different one.
Hi @Neil1175  are you saying you can't use your data in Corfu ? Have you checked you haven't reached your monthly spend cap as well as the roaming cap ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
