Discussion topic: Data roaming issues in Canada
This message was authored by: Poppy-40
I am using the £2 per day roaming which includes Canada.  I can't get a connection today.
how can I tell what data I have used?  I haven't had warning to advise I am near limit. Just the texts each day to see it is renewing.  I can't see in the Sky app.
 If data all used, it is possible to add more in this billing period?
thank you
Re: Data roaming issues in Canada
@Poppy-40
I've moved your post from the Talk board which is for Sky Talk landline issues.
There is now a fair usage policy. Roaming using Roaming Passport Plus is now limited to 25GBper billing period then it's £2.50per GB.
From Skys own website...
When you roam using our Roaming Passport Plus, we consider that up to 25GB per billing period is a reasonable amount of data to use. If you exceed this amount, we'll assume that you're no longer using data in the way expected of a reasonable customer for periodic travel. https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
Its worth adding that Sky can suspend subscriptions for overuse.
Also be aware of issues some customers are having in Canada duscussed here
https://helpforum.sky.com/t5/Sky-Mobile/Sky-stopped-working-whilst-in-Canada/td-p/4998989
This message was authored by: Kevin+Stokes
Exactly the same happened to me tobay too.... still trying find out what/why. Nothing from Sky at all. Very annoying. Kev
