Discussion topic: Corfu and activated roaming passport however charged as though in Albania
This message was authored by: Sunshine1106
My Daughter has recently been in Corfu and whilst at the beach activated the roaming passport this has resulted in £43 charges as though she was in Albania when she wasn't there. Will Sky refund the charges ?
Re: Corfu and activated roaming passport however charged as though in Albania
This happens when you are close to a border which is why you need to make sure the device only connects to a network from the country you are in.
As for a refund as customers we couldn't possibly say but there is no harm in asking Sky to see what they say.
@Sunshine1106 wrote:
... as though she was in Albania when she wasn't there. Will Sky refund the charges ?
This can occur if being near another country and the phone is set to 'automatic' network selection.
If the phone connected to an Albanian carrier then she is liable for the charges even if not intended.
Although, she can only phone and see if they are prepared to apply goodwill.
@Sunshine1106
Very unlikely. It's a common occurrence that visitors to Corfu and/or parts of Greece pick up Albanian networks I'm afraid.
This message was authored by: Ermine
Just phoned Sky to see if they could help with accidental data  roaming charge of £100 for Albania ( very close by) whilst in Corfu one afternoon, although I had paid for the £2 EU roaming in Corfu.  They said they could do nothing.
I see in the small print that it is your responsibility to ensure you  are joined to the right network. Hmmmm !
Unfortunately the default network connection is usually set to 'automatic'.  I recommend selecting manual.
Review your spendcap to at least limit the impact but if Sky aren't prepared to apply goodwill then it's payable.
