1
This discussion topic has been answered Discussion topic: Charging port
This message was authored by: Debz8
Charging port
I have a message saying there is moisture or a foreign body in my charging port which is not allowing me to charge my mobile, any clues ?
This message was authored by: daveNOS Answer
Re: Charging port
@Debz8 Is that message showing up when you try to charge? If so it may be worth trying a different cable to see if that makes any difference, if it doesn't then you will have to get the device looked at by either calling Sky to start the repair process or at a local mobile phone repair shop(this option may void any warranty if your phone/device is less than 12 months old).
Re: Charging port
