Discussion topic: Charged for calls I do not answer in the UK
This message was authored by: Bigtel1
Why am I getting charged for incoming calls on my mobile from 0843 numbers, I have registered with TPS but I still get the calls which I do not answer?
Re: Charged for calls I do not answer in the UK
Unfortunately registering with TPS will only reduce incoming calls for those companies that abide by it.  Many (overseas) companies/scammers do not.
However, you should be charged for any incoming call unless you are roaming?
