Discussion topic: Changing mobile provider, will sky inform old provider
This message was authored by: Digkit
Will sky inform my old provider I have left them
Re: Changing mobile provider, will sky inform old provider
@Digkit
If you use a pac code then your mobile number can be transfered from your other network to Sky, it is then up to you to make sure your account with them is closed and that either you don't owe them any money or if they owe you a refund.
https://www.sky.com/help/articles/switching-to-sky-mobile-keep-your-number
Buy the Sky sim
Activate it when it arrives but do not put it in your phone.
Get pac code from your current supplier
Give Pac code to Sky
When your current sim stops working insert your Sky sim in the phone.
No.
Unless you take positive action then your old provider will continue charging you.  (That can either be by using a PAC code or by giving them notice to cancel)
