Discussion topic: Carnt make or receive calls , says number is not recognised. I
This message was authored by: Cw661
I keep not being able to make and receive calls unless i turn flight mode on and off again . Its happening almost every day . I am missing calls . Does anyone know why this is happening please
Re: Carnt make or receive calls , says number is not recognised. I
Have you been abroad recently ?
This message was authored by: MJH5
Hi. I'm having the same trouble and I've only just got emergency calls only.
Avatar for Cw661
No not been abroad at all
This message was authored by: twilight+princess
Is there any error?
Is the signal strength ok & that you're seeing the Sky logo at the top of the screen?
Have you resent the Sky settings to your phone via your account?
Have you checked for any mast problems in your area?
Do calls work via WiFi calling?
In the end you may need a replacement sim to be sent out.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Avatar for Cw661
  • @twilight+princess
  • Thank you , i dont have any errors and if i turn flightmode on then off it starts letting me make calls
  • I am having to do this everyday
Have you tried the suggestion I mentioned?
Virginia.
