Discussion topic: 5G won’t work
Message posted on 02 Aug 2026 01:23 AM
5G won’t work
Hi have iPhone 17pro with ESIM ans 5 G won't work!
gone through ALL the settings and still won't work. It's activated but won't connect.
Message posted on 02 Aug 2026 05:56 AM
Re: 5G won’t work
Hi @Antb79 have you activated the 5 G add on from this page ?
https://www.sky.com/help/articles/sky-mobile-5g
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 02 Aug 2026 09:54 AM
Re: 5G won’t work
Hi yes done all that. As far as I can tell it should be all on.
turned it on about 2 months ago and it's never worked!
have coverage in my area, I've checked all the settings, reinstalled the network settings from sky but nothing
Message posted on 02 Aug 2026 10:06 AM
Re: 5G won’t work
Out of interest, does 4G work ?
Message posted on 02 Aug 2026 11:18 AM
Re: 5G won’t work
Hiya yep 4G is all good, good signal. Everything seems all good just can't get any 5G
Message posted on 02 Aug 2026 11:21 AM
Re: 5G won’t work
Sorry but just checking @Antb79 you have tried settings, mobile service, mobile data options, voice and data set to 5G auto ?
Message posted on 02 Aug 2026 11:44 AM
Re: 5G won’t work
Hi yes gone through all the settings.
reinstalled all the network settings from sky just to make sure there was nothing off in there. Next step is to call sky.
Message posted on 02 Aug 2026 11:51 AM
Re: 5G won’t work
Do you have an Apple Store near you @Antb79 probably get more help there ?
Message posted on 02 Aug 2026 12:17 PM
Re: 5G won’t work
Are you in a 5G area which is covered/supplied by 02?
I don’t work for Sky.
If I have helped then please leave a like.
Message posted on 02 Aug 2026 12:34 PM
Re: 5G won’t work
Hi guys, Apple Store good shout, going by one today, I'll get them to take a look.
yea have full coverage in my area. Used to be on 02 before sky.
Message posted on 02 Aug 2026 02:55 PM
Re: 5G won’t work
Hi update been in to sky and my account is in an "invalid state". Had total to HQ to get sorted on the network which will take up to 3 days.
so thanks for your help all, much appreciated.
