Discussion topic: Watching Sky Q recordings with Sky Go
Message posted on 16 Oct 2023 07:41 AM
I read on a Sky website page that I can watch Sky Q recordings on Sky Go whilst on the same network as the Sky Q box. What if I'm away from home (though still in the UK)? I can be on the Internet but not on my home network.
Message posted on 16 Oct 2023 10:13 AM
Re: Watching Sky Q recordings with Sky Go
You do have to be in the same property and the same network that the Sky Q box is on for this to work as being somewhere else will not allow you access to the recordings.
Message posted on 16 Oct 2023 12:36 PM - last edited: 16 Oct 2023 12:39 PM
The only product which ever offered such 'placeshifting' was the now defunct Slingbox.
https://en.wikipedia.org/wiki/Slingbox
Note that you can download most (but not all) Q recordings to a Go device while at home and then watch those elsewhere using the stored data if you have the Go Extra product.
Message posted on 22 Oct 2024 02:29 PM
Wenn ich im selben Gebäude und im selben Netzwerk bin brauch ich auch kein sky go mehr um meine Aufnahmen zu sehen. Dann kann ich gleich über meinen sky q receiver schauen. Was für ein Nonsens.
Sky, redet bitte nicht mehr von innovativer und moderner Technik. Das hier ist Mittelalter.
Message posted on 22 Oct 2024 03:27 PM
Which roughly translated says: "If I'm in the same building and on the same network, I no longer need Sky Go to see my recordings. Then I can watch straight away via my sky q receiver. What nonsense. Sky, please stop talking about innovative and modern technology. This is the Middle Ages."
Message posted on 14 Jan 2025 03:23 PM
Right!... Whay absolutely rubbish... Seriously.. than what's even the point having Sky Go if you're able to watch on a normal tv... I thought the entire point was that you could watch your programmes AWAY from home... hence... the "GO" bit 😳🤣🤣🤦♀️ x
Message posted on 14 Jan 2025 05:59 PM
You might be able to if you have already downloaded them (if the option is available) before leaving your home,
Message posted on 15 Jan 2025 08:52 AM
Downloading before leaving home is the middle ages, to borrow a phrase from earlier. What about programs that are recorded after leaving home, how would I access these?
Message posted on 15 Jan 2025 10:17 AM
You can't access them until the app is on
the same network that your Sky Q box is.
Message posted on 15 Jan 2025 10:20 AM - last edited: 15 Jan 2025 12:18 PM
Quite possibly, but no effective alternative has emerged and as I noted above back in 2023 the only longstanding 'placeshifting' system (Slingbox) closed down in 2022. Historically any such platform has been hampered by a combination of slow outgoing broadband speeds and the rights-holder requirement for broadcasters to enforce HDCP encryption on their content which isn't possible over a retransmitted IP video feed: while the former has now largely been solved by FTTP, the latter is still very much in play.
It's of course also worth noting that all current Sky Q hardware is incapable of such a task, and is now itself an end-of-life product last respecified in 2019.
Message posted on 15 Jan 2025 12:59 PM - last edited: 15 Jan 2025 02:16 PM
A data file created from broadcast content (aka a 'recording') being held on a Sky box hard drive isn't a 'programme' in this context. It can be viewed on the television connected to that box (and Mini boxes) after decoding by the box itself, and also becomes playable when transferred to a Go app device, but file transfer is only possible when both hard drive and Go client are on the same local network.
When away from the subscription address, live and on-demand content is streamed into the Go client directly from Sky servers: it's not coming from the home hardware.
