Discussion topic: Technical fault
This message was authored by: Reg36
Technical fault
I can't get on to sky go with my iPad it keeps saying it's a technical fault. Could somebody please help me.thanks
Re: Technical fault
What have you done to try and fix it, so have you tried deleting the app, rebooting your iPad then installing the app once more ?
Avatar for Reg36
Re: Technical fault
Yes I've done all that and it still comes back as a fault
