Discussion topic: Skygo on sky stream
This message was authored by: FJWoo
Skygo on sky stream
Recently got sky stream and I was told I could login to my skygo via the app, can anyone confirm this works?
Re: Skygo on sky stream
@FJWoo  It should do yes, just login to the sky go app on pc , laptop or mobile devices with your sky account login details
Avatar for FJWoo
Thanks @SKY1992bf I will give it a go, do I have to download the app or will it already be downloaded? Apologies not received it yet!
@FJWoo  The app needs to be downloaded from the likes of apple iTunes, google play or windows App Store
Avatar for FJWoo
Ok apologies I never read the response properly and may not have explained! I have an existing sky account which I use skygo on however I am installing sky stream at another property and was informed I could use the skygo app on/through sky stream therefore only needing a basic package at the other property, any idea if this is true?
@FJWoo  No the sky go app is not available via sky glass/stream puck themselves, the only way to use the app on the second account is as already advised
Avatar for FJWoo
Thanks, slightly mislead by the rep who sold me it then but it will still have its advantages, I will ensure I take the laptop also!
thanks again!
