Discussion topic: Sky go not working
This message was authored by: Alf18
Sky go not working
Sky sports is not working on the sky go app keeps saying upgrade your subscription
Re: Sky go not working
@Alf18
If you are using a mobile or tablet then does the Sky Sports app work instead ?
This message was authored by: Tomhouston
Sky sports on sky go
When trying to play sky sports on the sky go app it doesn't work and says I need to upgrade my subscription even though I have one.
It does work on the sky sports app however so not sure if it's a sky go issue?
Re: Sky sports on sky go
Do you have Sky Q @Tomhouston and if so if the app is connected to the box what happens if you go into settings on the Sky Go app and disable the connection, does it then allow you to view the sports channels ?
