7
This discussion topic has been answered Discussion topic: Sky go not installing
This message was authored by: and3969
I installed sky go on my new levano laptop (windows 11) and it worked fine for a couple of months but then stopped working, showing a java script message. I unistalled it and when I tried to re-install, got the message below:
Any ideas gratefully received - am a complete IT novice
Thank you
Re: Sky go not installing
@and3969
Possible help here:
https://learn.microsoft.com/en-us/answers/questions/4221742/error-5-access-denied-pops-up-when-tryin...
@and3969
Possible help here:
This message was authored by: Lynn+Norman
Error message when trying to install SkyGo.
Re: Error message when trying to install SkyGo.
@Lynn+Norman
I have moved your post to here asa another member had the same issue yesterday so have a read through the link im my post which is above yours.
Thank you! Just followed the steps exactly as in the link and it worked! All now installed.
So very grateful for your help.
Avatar for and3969
Hi
I tried the tip, managed to get the app back on my laptop. However when I tried to open it, the screen saying checking for updates was there for ages before getting the message below:
I tried again but got the same message - any help gratefully received
Thank you
@and3969
This was posted by another member so might be worth a try:
Where is says USERNAME is it the name you use with the PC.
a) Click Start, type 'Firewall' and select Windows Defender Firewall.
b) Top Left of this window, select 'Allow an app or feature through Windows Defender Firewall'
c) Bottom Right, click on 'Allow another app.'
d) Click Browse and Manually navigate to the Sky Go exe file using the
e) "C:\Users\USERNAME\AppData\Roaming\Sky\Sky Go\Sky Go.exe" the location of the exe.
d) Add this exe to your list of Firewall exceptions.
e) Check the list and make sure Sky Go is there and it's box is ticked.
Try Sky Go.
Avatar for and3969
It has worked - sort of - I have to right click on the icon and click on 'run as administrator' but at least I can get it working
Thank you
