Discussion topic: Sky Q box not enabled to connect to Sky Go
This message was authored by John+Boyle This message was authored by: John+Boyle
I have a sky go extra subscription but no multiscreen. My Sky Q Box shows 'Sky Box not enabled to connect to Sky Go' and trying tyo re-activate wont work. I know others say that youbhave to have multiscreen, but surelt the subscription overrides this requirement? Any ideas? Thanks
Re: Sky Q box not enabled to connect to Sky Go
Afraid you need the Q Multiscreen subscription in order to connect any Sky Go device to your Q box @John+Boyle
John+Boyle
But Sky.com says "You’ll need a Sky Multiscreen or Sky Glass/Sky Stream Whole Home subscription, or you can pay the monthly cost to use it (Sky+ and Sky Q customers only)."
I'm not sure what that last bit means but if you want to connect the Sky Go app to your Q box then you do need a multiscreen subscription as by doing this the app is seen as another screen which is why multiscreen is required.
On average, new discussions are replied to by our users within 3.6 hours
