Discussion topic: Sky Go won't load on Win 11 box
This message was authored by: Yebam
My Sky Go won't load on Win 11 box. It loads a PFE 4002 error which goes away, it then asks about cookies. When you complete that, the login dialog appears and disappears before you can complete it 😞
I have uninstalled Sky Go and cleared all folders relating to Sky Go.
I have uninstalled VLC media player,
I have made sure nothing is running which can perform screen captures like the snipping tool
I then re-installed Sky Go and have the same issue.
Re: Sky Go won't load on Win 11 box
This is what has worked for some on Windows 10 previously with this error:
Right-Right click on Sky Go Short cut on the desktop.
Select 'Properties' then 'Compatibility'
Uncheck box ' Run this program in compatibility mode for’ and press OK
Relaunch Sky Go App then retest, if white screen hangs on login box restart PC to Fix.
Or give this a try if the above doesn't work:
click on the Sky Go app and click on Compatibility.
Go to change settings for all users at bottom of pop-up.
Check the boxes "Run as administrator" AND the box beneath that says "Register this Program for Restart".
Click Apply.
This should take you to a screen where you have to sign into your Sky account.
Avatar for Yebam
Level 2 icon
I have tried all those suggestions, it still won't load.
Try on a clean install of windows
Avatar for Yebam
Level 2 icon
I don't have the time or energy to reinstall Windows only to find Sky Go still doesn't work - sorry.
No worries, have fun finding a solution 🙂
