Discussion topic: Sky Go will not play Formula 1 Sky Q recordings
This message was authored by: Millsyboon
Hi
For some reason I cannot play recordings of F1 using Sky Go on my laptop or iphone, it used to work last season. I can play Sky F1 live and I can play any other recorded programme, has somethign changed with the programme licencing that is preventign this?
Richard
This message was authored by: cousinDave
Re: Sky Go will not play Formula 1 Sky Q recordings
Sky Go isn't working for me to watch the qualifying live either. Just ge t a message saying "Live Saudi Arabian F1 GP Quali is currently unavailable, please try again later"
@cousinDave
I think the OP can watch live tv where you can't so what device is the Sky Go app installed on ?
Its on an Android phone. I've tried viewing a live football match and that worked ok.
Can you try installing the Sky Sports app as you can watch the live sports channels via this so see if the F1 channel works for you when viewing it via this instead of the Sky Go app.
@caesarome
I wasn't aware of this app, but yes this works. Thanks for your help.
@cousinDave
Good stuff.
Avatar for Millsyboon
Mine is working now, why does the app list UHD content that you cannot play through SkyGo? HD content is working, just means having to record 2 versions of every race and qualifying.
