Discussion topic: Sky Go using all my mobile data even after downloading to phone
This message was authored by: alixholloway
Recently changed to Sky and have been using Sky Go to watch on train and I download each programme before going out, but I hav found all my data has been used.
Re: Sky Go using all my mobile data even after downloading to phone
If you are a Sky TV and Sky Mobile customer then this shouldn't be happening @alixholloway so when you say it is using this data it is because your Sky account via the MySky app is showng the data as being used or your devices own data monitor ?
Avatar for alixholloway
I actually have my mobile with Vodafone. Are you saying that unless you use Sky as a mobile provider you don't have the ability to watch downloaded films etc off line? I didn't have this issue with Virgin and don't with Netflix.
No sorry I misread your opening post.
When did you download this content, did you do it when you were at home on a Wifi connection because watching back downloaded content should not use any data especially if you have mobile data turned off.
No probs
So yes always at home with WiFi.
Yes, exactly that is what I thought.
But I haven't got mobile data switched off, I will try that when I go out next and see if it still happens
It sounds like that instead of it playing the downloaded version it opened up the streaming version of the show. When you started watching the show did you access it via the "downloads" section of the app?
Yes I did.
I've looked through the other forum posts and can't find anything similar.
Yes I did.
Yeah this deffinately seems strange. Would be interesting to see what happens when switching mobile data off next time.
Let us know how you get on as it shouldn't been using data against already downloaded content
