Discussion topic: Sky Go sound sync issues on airplay
This message was authored by: BerwickBrummy
I use Sky Go on a macbook then airplay to a speaker.Its fine on BBC Iplayer but with Sky Go there is a significant audio delay.Its all fine on the Macbook internal speakers.So what's going on with Sky go versus I player??
This message was authored by: Alan159
Re: Sky Go sound sync issues on airplay
I also have this issue. Did you find a solution?
