6
This discussion topic has been answered Discussion topic: Sky Go pin
This message was authored by: Btisbetter
Sky Go pin
I have been trying to set up a Sky Go pin unsuccessfully for 45 mins. I go through the settings on the app, which should take me to the parental controls but I just can't find where it is. I also tried the tv but theres nowhere on that for skygo.
So far I've tried the tv, the Sky Go app, My Sky website and manage devices. Just cannot find an option to create a pin to download programs. What am I missing?
Re: Sky Go pin
@Btisbetter
It looks like it has moved so try this link instead:
https://www.sky.com/productsettings/tv/parental-controls
Re: Sky Go pin
@Btisbetter
If the Sky Go app is not connected to a Sky Q box then the pin for it can be reset here:
https://www.sky.com/manage/tv/manage-devices/change-pin
Setting parental control level:
https://www.sky.com/myaccount/tv/manage-devices
Avatar for Btisbetter
Re: Sky Go pin
Thanks for your answer.
I've tried both and I just get the option to change the name of the device or delete it.
I can watch programmes on it but not download.
Re: Sky Go pin
@Btisbetter
This message was authored by: NiCG1
Re: Sky Go pin
I was having the very same issue and this link helped me fix it thanks.
This message was authored by: Carrieanne89
Re: Sky Go pin
Im having the same issue please help neither link works
Re: Sky Go pin
 i get this after clicking links
