Discussion topic: Sky Go pin
This message was authored by: Tuffty
Sky Go pin
In trying Sky Go, on my iPad, or on my PS5. I noticed I need to set up a device pin, in order to watch the Sky Cinema channels, if the movies are age restricted. I go to the page to set it up and there is no method to set up the Sky Pin. I am on Sky Stream.
If anyone could help. It would be greatly appreciated
Thank you.
Re: Sky Go pin
https://www.sky.com/manage/tv/manage-devices/change-pin
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
Please note: Free (advert supported) Hayu content is available via the On Demand section of your Sky planner, you DO NOT access the free content via the Hayu app!
Re: Sky Go pin
@Tuffty
Give this link a try as the above link posted by @Annie+UK is for the Sky Tv pin so this one can be used for Sky Go:
https://www.sky.com/productsettings/tv/parental-controls
