12
This discussion topic has been answered Discussion topic: Sky Go not working on 2 Window 11 systems and a Mac
This message was authored by: petevick1
Sky Go is not working on  both my Windows 11 systems, and my Mac Mini. All systems are running latest version of the OS.
Sky Go starts, displays 'Downloading Update" and then just sits there with a blue screen. Tried dropping the firewall - no diffference. It can't be the network as it runs on the iPad and iPhone . Uninstalled and downloaded 23.5.1 and re-installed - no difference.
Any clues???
Avatar for petevick1
This message was authored by: petevick1 Answer
Re: Sky Go not working on 2 Window 11 systems and a Mac
Sorted it!
Uninstall Sky Go, and then go to 'manage devices' and remove the PC that is causing the problem.
The download the SkyGo installer, and run it. It will ask about cookies, and then will prompt for you uset name and password. And it works - or at least that worked for me!
This message was authored by: Mr+Flibbles+86
This message was authored by: Cudd
I have exactly the same issue with the same version of sky go on my mac. Sits there on blue screen and does nothing. I have even deleyed the app and re downloaded it. Still the same.
Deleted* the app
This message was authored by: Addie15
Update-We are closing this session as we have not received further response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
you were referring it to the development team, and haven't had a response. I have not got a solution to this and the ball is in your court!
Sorted it!
This message was authored by: Petesmit
Recent Chat with Sky re SkyGo not working new SSD and clean install of Windows 11...worked fine prior to this on Windows 11....
I'm really sorry you've been having issues with the Sky Go on your PC. Having checked your account and our faults page, It is something that we are aware of and support teams are investigating this issue.
I can see you have tried most things to resolve, but currently our only suggested work arounds are as followed
1: Restarting the app (this could take several attempts)
2: Closing down other applications that are currently open, then attempt to open Sky Go
3: Shutting down the device (not restart) and turning it back on, then retrying Sky Go
4: Try opening the app when connected to a different broadband connection (at work / home / mobile tethering)
If none of these options work then unfortunately we will just have to wait for a fix to be in place and currently we do not have an estimated date as to when this will be, but the resolution is being worked on.
Please see my answer from 25 Aug
Have tried everything numerous times but to no avail
This message was authored by: Brandonm17
I am having this same issue, The app opens and i can go into settings etc but TV Guide, movies etc will not work, this issue only happened recently, Was working fine before Christmas
This was posted elsewhere by another user and after anoither update gfrom Sky rendering the app not working again I tried this and it worked
23 Feb 2024 05:25 PM
Give this a try:
Right-click on the Sky Go app and click on Compatibility.
Go to change settings for all users at bottom of pop-up.
Check the boxes "Run as administrator" AND the box beneath that says "Register this Program for Restart".
Click Apply.
This message was authored by: AndyB68
Hi everyone,
Having had the same problem as you, i have now found a solution that works.
1. Delete app
2. restart pc/laptop
3. Download the sky go app.
4. after it has downloaded, go to your downloads folder and then right click on the sky go app and click on       run as administrator
 You will have the sky go app running after it has updated etc........
Answered - Go to Answer
