Discussion topic: Sky Go devices
This message was authored by J.Ames91 This message was authored by: J.Ames91
Sky Go devices
I am having major trouble removing a device from my sky go devices. I have had a big falling out with a friend and don't want them to have access to smy sky go. I have changed my password twice and removed the device (Playstation) more times than I can remember but they still manage to gain access. Can anyone help. How do I block them?
This message was authored by Barry+25 This message was authored by: Barry+25
Re: Sky Go devices
Hello if you tick remove device on sky go then remove customisation then they need a new key ie password to log in but if you changed password they won't be be able to.
This message was authored by Invisiblename This message was authored by: Invisiblename
Re: Sky Go devices
That's as clear as mud - fancy re-typing that for the OP?
I am just another Sky customer!
Re: Sky Go devices
@J.Ames91
Doing this will kick them off:
https://skyid.sky.com/resetpassword/
Then go to this link:
https://skyid.sky.com/authorise/manage
If you tick "Sky Apps" and then the remove button, then anyone using SkyGo or SkyNews or SkySports apps etc. using your credentials will have the previous auth token removed and will be forced to sign in again (using the new password only you know). Will mean people you want to use your ID will need to do the same, but will force whoever is using your previous details off, this might not stop them straight away but it will over a day or so.
J.Ames91
Re: Sky Go devices
We have tried this several times but the person is still able to access. Any ideas ??
Re: Sky Go devices
I'm stumped because it should kick them off after 24 hours or so if you have followed the instructions correctly so especially the second part about selecting apps.
This message was authored by popacatapetal This message was authored by: popacatapetal
Re: Sky Go devices
You could check if you have any rogue "Additional Users" set up on your account. Remove them in account settings.
Something like this was mentioned a year ago or so regarding sky users in a student house and the fact that additional users can still change sky account settings.
Re: Sky Go devices
@popacatapetal
Just removing them doesn't prevent them from still using Sky Go which is why you have to also take the extra steps I mentioned above in my earlier post,
J.Ames91
Re: Sky Go devices
Unfortunately the issue is still persisting. Ive tried everything you have suggested Any further ideas ?
This message was authored by Adam9138 This message was authored by: Adam9138
Re: Sky Go devices
Im having the same issue and they still kepe usong the sky go and when spoken to the sky team on the phone it made no difference at all.. ive done all steps provided by sky and seen on internet and still on my account using my sky go, any help anyone??
Re: Sky Go devices
@Adam9138
Did you do this:
First change your password:
Re: Sky Go devices
Yes done that still same issues @caesarome
This message was authored by Jade.97 This message was authored by: Jade.97
Re: Sky Go devices
The only thing that worked for us was to change the email address that's on our sky account. We changed from mine to my wife's. Changed the password again and so far it's been a success.
Re: Sky Go devices
Spoiler
Just to emphasise the point. My username is now Jade.97 where I used to be J.Ames91
Re: Sky Go devices
I tried changing email but it jept saying error
On average, new discussions are replied to by our users within 3.6 hours
