Discussion topic: Sky Go channel numbers
Message posted on 25 Feb 2023 11:11 AM
There seems to be a conflict with the Eurosport Channel numbers on the Go App compared to my Sky box. On my box Eurosport 1 and 2 HD are channels 410 and 411 respectively while the non HD channels are 868 and 869. But when looking on the Go App the non HD are shown on channels 410 and 411 while the HD channels are on 868 and 869. Is this just an error on the graphics in the app? If I want to use the app set recordings should I select those on channel numbers 410 and 411 to get HD, even though they are listed as the non HD in the app??
Message posted on 25 Feb 2023 01:19 PM
Re: Sky Go channel numbers
Sadly this is a new issue as it has been going on for many years. From memory I believe you have to select the HD channel so in your examples 868 and 869.
