3
This discussion topic has been answered Discussion topic: Sky Go asking for device authorisation
This message was authored by: AndyP59
I had the same problem in the summer last year. It has reappeared.
I have Sky Q subscription and hardware, with mini boxes and sky go.
Sky go waws working fine, then stopped and gave me error code 4*2*5*3*0*2*4*4*2*1.
Tried everything suggested in the forums including reinstalling sky go.
Now get a message saying that the device - iPad Air 4 Gen, using OS 18.3.2 - needs to be authorised
All pretty much as last year.
Cannot find anything on website or VIP site on how to authorise a device
Now stuck with a not working sky go.
please advise
many thanks
Re: Sky Go asking for device authorisation
Are you using a VPN because if so it will need disabling before starting to use Sky Go.
Avatar for AndyP59
I put the stars in as system wouldn't allow the unstarred error code (or parts of) as it had been used too often!
Avatar for AndyP59
Have disabled VPN, and now it is working. But VPN was working before.....
many thanks for assist, but sad, that for some reason that isn't clear, I now have to disable device security to watch Sky go.
cheers
