8
This discussion topic has been answered Discussion topic: Sky Go - Whats my Device Pin
This message was authored by: Ian+Horwood
Hi there,
I tried to watch Raiders of The Lost Ark Sky Cinema on my iMac. Sky Go asked for my device pin. I thought this was the pin I use on Sky Q (for age related movies and watershed etc) it said this was incorrect. I mean it was the right code, just not my device PIN.
I went on to My Sky and found my devices (6). My iMac is on there and i expected to find a PIN for each device, but no, that would be too easy.
I can watch the movie on my MacBook with no issue and no pin required.
I am able to watch normal TV programmes but not Sky Cinema for which I have a sub.
So, how do i establish what my Sky device pin is for my devices please?
Avatar for Ian+Horwood
This message was authored by: Ian+Horwood Answer
Re: Sky Go - Whats my Device Pin
Thanks for your reply. No, red herring. Sorted now thank you
@Ian+Horwood If you've forgotten your PIN it may be the last four digits of the phone number you have registered with Sky.
Further help here:
https://www.sky.com/help/articles/your-pin
@Ian+Horwood
The pin for Sky Go can be setup here:
https://www.sky.com/productsettings/tv/parental-controls
Thank you for your help guys. I've sorted this now.
At the risk of looking foolish and for future reference for anyone else.
I went to watch the movie on the TV listings...  Mistake. When I went directly on to Sky Cinema On Demand I was able to watch any movie on my iMac without entering a device pin at all.
Fascinating stuff...
Cheers anyway
Ian
This message was authored by: RobbieBensonGib
What is my device pin please
This forum is primarily customer-to-customer help, you're not talking to Sky support
@RobbieBensonGib
Is the Sky Go app asking you for a pin when you try to view something ?
This message was authored by: khain147
FYI default Sky Go PIN to watch live TV seems to be 0000 🙂
