Discussion topic: Sky Go Stuck on initial screen
This message was authored by: R_Padge
Downloaded the latest app for my PC. Gets stuck on the first downloading update screen and nothing else happens. Doesn't work at all. Same result on my laptop.
Re: Sky Go Stuck on initial screen
@R_Padge
Mine updated yesterday as it was the first time used it and from when it started to update to me be able to use it was about 6 or 7 minutes so have you tried leaving it for a while to see what happens or have you already done this ?
Avatar for R_Padge
I will try again and see.
Avatar for R_Padge
No joy, literally just does nothing. Downloading update message forever.
Avatar for R_Padge
Fixed it!
Right click the SkyGo shortcut > properties > compatibility
CHECK the boxes "Run as administrator" AND the box beneath that says "Register this Program for Restart".
Click Apply.
Then on re-launch the windows firewall pop up apeared (which I allowed) and it logged me in as normal.
So far so good!
