Discussion topic: Sky Go Crashes after checking for upgrade
This message was authored by: Debi16
I have windows 11 and Sky Go will not load, it comes up checking for updates and then after a few seconds closes.  I have tried the compatibility checker which did not work.  I have checked my firewalls, and it is an accepted App.  I have completely uninstalled and reinstalled.  I should say it used to work fine on Windows 10.  I am not sure if this problem started when I upgraded to Windows 11.  Anybody got any ideas.  I have been reading all the discussion threads and tried all the above which have not worked at all.
This message was authored by: Addie15
Re: Sky Go Crashes after checking for upgrade
Hi there Debi16, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for Debi16
Thanks Sky for your help  identifying the problem.  Citrix was installed which was preventing Sky Go opening. Once Citrix was uninstalled problem gone.
This message was authored by: Lisa-P1987
Update - Spoken to @Debi16 their Sky Go issue is resolved now 🙂
Lisa - Sky Tech Team Expert
This message was authored by: OliMuc
Citrix and Sky go are working together (at least for me) if you do the following
Uninstall Citrix and reinstalled it without the "HUB" option.
Command line:
"CitrixWorkspaceFullInstaller2508.exe" ADDLOCAL=ReceiverInside,ICA_Client,AM,SELFSERVICE,DesktopViewer,Flash,Vd3d,WebHelper,BrowserEngine
