Discussion topic: Sky Go Application on Macbook Pro
This message was authored by: Boyd13
I am having issues similar to Rambo256. I cannot seem to get my Sky Go application working on my Macbook Pro. I have deleted and reinstalled. When loading it I just get the loading circle in the middle of the application. But that does not change.
I have had this issue for months now and was just hoping with each Mac Update that this would be fixed, but it hasnt.
Are you able to help please?
This message was authored by: Jones_The_Cat
Re: Sky Go Application on Macbook Pro
What type of MacBook Pro are you using? Which OS are you using?
Sky Go (23.5.1) runs perfectly fine on my M1 MacBook Air with Sonoma 14.2.1
This message was authored by: Boylec325
I have the same issue and have. been trying to get thos resolved for a. couple. ofmopnths now. I called Sky direct and gave all the details. nobody has called back at all.
This is very frustarting. Any help will be massively appreciated.
Avatar for Boyd13
@Jones_The_Cat Hi, I have the Macbook Pro 13 inch 2020. My OS is macOS Sonoma 14.2.1 and cant seem to get it to work at all.
Its really frustrating as I travel for work and often relied on sky go for my entertaiment.
Sky please help us fix this issue.
