Discussion topic: Remove device sky go
Message posted on 17 Feb 2023 11:23 AM
Hello
I've changed my sky password 3 times
and removed the device but the person is still able to log in to sky go Please can someone help
Message posted on 17 Feb 2023 01:17 PM
Re: Remove device sky go
There is another step you need to take:
Change your password again then go to this link:
https://skyid.sky.com/authorise/manage
If you tick "Sky Apps" and then the remove button, then anyone using SkyGo or SkyNews or SkySports apps etc. using your credentials will have the previous auth token removed and will be forced to sign in again (using the new password only you know). Will mean people you want to use your ID will need to do the same, but will force whoever is using your previous details off, this might not stop them straight away but it will over a day or so.
