Discussion topic: Remote Recording on Sky+
Message posted on 24 Mar 2024 06:39 PM
Can someone tell me if it's still possible to remote record on Sky+? I know you used to be able to use the Sky+ app but that's no longer available. Using the Sky Go app, I find the programme, press record once on sky box, and it says the request has been sent but it doesn't record.
Even if it were to work, we have two sky boxes, so how does the app to know which box to send the recording to?
Message posted on 24 Mar 2024 07:34 PM
Re: Remote Recording on Sky+
It is still possible but as you have discovered you can not use the TV Guide so you will have to use the search to find the content you want to remote record.
It should work as it does for me so are you logged into the app with the correct Sky ID ?
I think the only way to do it is tow set up a second ID that is set to remote record to Box 2 then you will need to make sure you are logged into the app with the correct Sky ID.
