This discussion topic has been answered Discussion topic: Need a PIN code to download
Message posted on 08 Nov 2024 11:00 PM
Before I can download anything on Sky go, it says I need to set up a device pin, despite following the instructions there does not appear to be ant option to do this , can you send me a link to directly go to the page needed
thanks
Message posted on 09 Nov 2024 05:45 AM
Try this link:
https://www.sky.com/productsettings/tv/parental-controls
Try this link:
Message posted on 09 Nov 2024 08:03 AM
Re: Need a PIN code to download
This worked! Thanks
Message posted on 09 Nov 2024 01:30 PM
Brilliant that worked a treat
can now download to iPad
thank you so much
Message posted on 30 Dec 2024 01:09 PM
Thank you so much!! I have tried for over an hour with various links in the site that do not work. Very much appreciate your time 🙂
Message posted on 26 Feb 2025 09:15 PM
Thank you for this post - is someone able to provide feedback to Sky that the advice and links from the app don't take you to this link and so it's impossible to fix unless you happen across this post. Both the links in the mobile app and windows app take you to the same incorrect link: www.sky.com/devicepin
Message posted on 08 Mar 2025 02:04 PM
Watch sky cinema on iPad with sky glass
I have Sky glass and I can now watch Sky channels on my iPad but when I want to watch a film it says I need to use my pin! Thanks fine but it doesn't give me the opportunity to enter it! Any ideas please!
Message posted on 08 Mar 2025 02:20 PM
Re: Watch sky cinema on iPad with sky glass
What's the exact message it says, just so we're all on the same page?
Message posted on 08 Mar 2025 02:22 PM
I can download sky on my iPad but sky cinema I need my pin but there's nowhere to insert it! I have Sky glass
Message posted on 08 Mar 2025 02:36 PM - last edited: 08 Mar 2025 02:47 PM
Try as it says there, click on the following link and check your parental controls;
Message posted on 08 Mar 2025 02:38 PM
https://www.sky.com/help/articles/your-pin-sky-go
Message posted on 08 Mar 2025 02:45 PM - last edited: 08 Mar 2025 02:48 PM
Have moved your post to the Sky Go section and this similar thread as the answered post should answer the issue.
Message posted on 08 Mar 2025 02:58 PM
I can't get Sky go on Glass! After TV it goes to Sky Go Devices ... opens the screen with Mamage your Sky TV Devices then..
Device Name
Device Information
....no way to enter Parental Controls
thank you for any help!
Message posted on 08 Mar 2025 03:00 PM
On a web browser can you go to https://www.sky.com/productsettings/tv/parental-controls?
